Modbus libraries for LabView 8.0
I tried your vi. But some more vis are needed. Can you pls help
thanks
Suresh
Message 41 of 81
(3,235 Views)
Hu 😃
I jave the same problem as discussed above. I am trying to communicate to Oega CN9600 (temperature controller) using LabView and nothing seems to work. Can anybody please advice me on what may be going wrong or show a sample code?
Thanks a lot
Message 42 of 81
(3,059 Views)
Hiii Tony,
               On which interface you are implementing the Modbus? Serial or Ethernet?For serial i have already uploaded the simple vi in this topic, and you can find ethernet on the forum. please provide us with ur vi, so that we can see n tell u wats goin wrong?
             I found that the Omega CN9600 is using the serail communication, so the vi i have posted can give you the idea, another thing you do is pls post your vi and apart from that download the "serial monitor" software from here, and after starting this software for your com port which you are using it for communicationg with your instrument, start the vi and to communicate with your instrument, so you will be able to see what query is goin to the com port and what is the reply coming on the com port, so you will be able to analyse.
hope this helps, but still you upload your vi, so that it can be analysed.
Nishant
Message Edited by Nishant on 01-22-2007 10:44 PM
Message 43 of 81
(3,053 Views)
Nishant,
can you post your MDmodified.vi in Labview 7.0 version?
Tony
Message 44 of 81
(3,015 Views)
Nishant,
here is the program that I am trying to use.
Thanks for your help
Message 45 of 81
(3,009 Views)
Hiii,
                Ya surely I am sending you original MBModified.vi, and i think you should use that only instead of what you are doing currently, i really couldnt understand the concept you are trying to develop, neways here in this post i am attaching the original MBModified.vi, you just use it by default by entering the necessary parameters.
Nishant
Message 46 of 81
(3,004 Views)
Nishant,
can you please save your file MBmodified3 for Labview 7.0 instead of Labview 7.1?
Anton
Message 47 of 81
(2,981 Views)
Also when I am trying to open your .vi some subvi's are missing (MBcrc, MBwaitForSerialDigStatus, MBwaitForSerialRegisters, MBconvertDecimal). Do you know where I can get them (they are definitely not in the ModBus library published earlier in this post).
Thanks a lot,
Tony
Message 48 of 81
(2,975 Views)
Hi Nishant,
just one thing: if you have time can you repost the file along with the following SubVIs:
(i) MCconvertDecimal
(ii)MBcrc
(iii) MBwaitForSerialRegisters
(iv) MBwaitForSerialDigstatus
Message 49 of 81
(2,775 Views)
Hi
I have read several of the Modbus threads without getting where I want. Maybe It's just me being very slow.
My task should be quite simple; I want to read 4 register values from an ABB ACS350 motor drive continuously. The ACS350 run a Modbus RTU protocol over a 485 line. I have downloaded the Modbus library and have tried to use the various modules without success.
Is there anybody that can point me in a direction? The motor drive adress is set to 1 and the registers I would like to read are 102, 104, 106 and 110.
Peder
Message 50 of 81
(2,739 Views)
