Modbus libraries for LabView 8.0
Jim-
I don't have Labview on this computer, so I am going from memory.  You will want to write to a single register the (decimal) value 1143 then 1151.  The control word is parameter 301, so the Modbus address is either 301 or 40301.  I forget if the NI library uses the 40000 offset.  A 40001 offset might also be used, but there are only a few choices, so try them all.  One thing to try first is to read the DC bus voltage, parameter 107, to test things out using the query.
Message 81 of 81
(722 Views)
