Modbus Write single coil not responding
I completed agree with you that Technical Manuals SHOULD BE clearly written
Oh, did you see my signature line?
"Should be" isn't "Is" -Jay
Message 11 of 12
(873 Views)
Never forget, ModBus is based on 16 bit registers. Perhaps, if you really pass a byte value to a function in your CodeSys environment it might actually work, because it would cast it to a 16 bit value, but I wouldn't rely on that. The byte value could also land in the high byte of the register.
Message 12 of 12
(864 Views)
