Can we convert queue to notifier by making the queue buffer size to 1
(1,921 Views)
Hi 26,
Technically "yes"/"kind of"…
There are lossy queues and you can avoid blocking behaviour of empty queues - but why don't you use a notifier when you need one?
(1,914 Views)
A Notifier holds a single Data Value AND a History object.   There is no method to remove (Flush) the Data or History.
This is NOT the equivalent of a Queue with a Max Buffer size of 1.  That Queue Buffer May hold 0 or 1 elements of Data and contains no history object.
Flush Queue and Dequeue operations will always leave the Queue you described with no elements.  In practice, you could always use Preview Queue to return an array containing the 0 or 1 Data elements in the Queue.....but the next developer will wonder what you were smoking when that wild idea popped into your head.
"Should be" isn't "Is" -Jay
(1,878 Views)
IIRC, not the Notifier itself but the callsite of the "Wait for Notifier" function has a history object. i.e. the timestamp of the last notifier which was returned so that the "ignore previous" can be used. This is a problem when "switching" notifier references on the same callsite.
But it is true that a Queue has no concept of "history" or "Ignore previous", if it has something, it will return it. If not, it won't.
(1,842 Views)
Thanks for your reply GerdW,
What does it mean "avoid blocking behavior of empty queues"
(1,793 Views)
Hi 26,
This has been explained by J...
(1,782 Views)
