Modbus Temperature Device (Slave) Display Value different from Labview displayed Value
When I read Register 1100, I still have same issue which is Display (=835)  is greater than labview value (=834) by value of 1. it was Register 1014 9CJC) that gave me a value (382)
Message 11 of 26
(1,046 Views)
When I read Register 1100, I still have same issue which is Display (835)  is greater than labview value (834) by value of 1. it was Register 1014 9CJC) that gave me a value (382)
Message 12 of 26
(1,046 Views)
So it likely is a round/truncate error.  what happens when you show 1 digit past the decimal point? is it 1 Degree or 0.1 Degrees different
"Should be" isn't "Is" -Jay
Message 13 of 26
(1,044 Views)
The value out of the register is an integer value without any decimal e.g 834 while the value on the display is shown as 83.5. So the modbus register value (834) has to be multiplied by 0.1 in the labview code in order to make it 83.4.
Message 14 of 26
(1,037 Views)
increase to 2 digits past the decimal .  Again we are simply triing to confirm ist a round truncate error
Message 15 of 26
(1,031 Views)
Just to make sure that it's not a bug of your LabVIEW code: Which modbus-API do you use?
Further suggestions:
Check as many different values as possible, as already stated here, it might be a bug (or feature Smiley Very Happy) of your instrument.
Regards, Jens
Kudos are welcome...
Message 16 of 26
(1,031 Views)
I am using Modbus RTU API. I have a gateway for TCP connection to Master (Labview Code) and serial connection to slave devices.
Message 17 of 26
(1,017 Views)
I did increase the digit to two places but the display was still showing me one decimal place of 83.5
Message 18 of 26
(1,014 Views)
Well, I wanted to know, if you use a widely available API, like Modbus Master by Plasmionique Inc. the "old" NI Modbus Library, the Modbus Library that comes with the DSC or RT toolkit, or anything else.
Regards, Jens
Message 19 of 26
(1,006 Views)
using NI Modbus Library
Message 20 of 26
(1,000 Views)
