Modbus Serial master error56
Dear Friends
I am using modbus library to communicate with an external slave device via modbus RTU. When I run the code it sometimes generates Error56 but sometimes it does not generate any Error and it runs correctly. What is the reason of this Error56?
V.S.
(3,170 Views)
Momentary glitches, phase of the moon, bad karma resulting from the music file you downloaded last night -- take your pick. On modbus I never accept an error 56 (or 66 either) unless it happens a couple times in a row. The thing to do is drop the connection and try to reconnect.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,145 Views)
