Modbus Serial Write to a single register
Hi, I'm trying to write command to my energy meter UEM80-4D R, the query message is correct, I try to change the bps on the meter through writing the command, but the setting on the meter didn't change, I do not know how to get the response message too. Any examples of write single holding register by using the Modbus library will be great.
Thank you
(2,665 Views)
Hi harry,
does your energy meter even support "Write Single Register" (as the error message suggests)?
(2,652 Views)
Hi, yes it does support, I write the command based on the example on the datasheet of the meter.
(2,647 Views)
Hi harry,
those images always show function code 10h=16d…
You use that function code 10h=16d when creating your own "message" indicator.
But you still use that WriteSingleHoldingRegister function! That function is using the ModBus function code 6 - and then your device responds with "unsupported function code"! Have you tried to write to multiple registers?
(2,621 Views)
Hi, I just tried what you have suggested, but i still encounter the error.
(2,611 Views)
Hi harry,
what happens when you send the bytes of that example (Capture.png from message #3) to your device using a simple VISAWrite command?
(2,607 Views)
