06-26-2019 03:35 AM
Hi guys!
I have been doing the labVIEW programming to transfer the data to the txt. document not only with the data but also having headers on the top. I have searched a lot like the website below:
http://web.mst.edu/~cottrell/ME240/Code-hints/File_storage.pdf
But this does not really help since this is only for 2D non-dynamic array.. What the problem is that I have more than 2D dynamic data even more in the future coming from the 'read' icon . I created something like PNG '' data transfer '' but that is useless at all -.-
I appreciate if anyone could help
06-26-2019 03:42 AM - edited 06-26-2019 03:42 AM
Hi River,
That example helps a lot! Just do as is described in your PDF!
06-26-2019 03:48 AM
Hi GerdW,
Thanks for your quick reply!
Place the header writing before your loop to obey THINK DATAFLOW!
Should I use concatenate String to combine the data writing with the data or other string would be better?
Best wishes
River
06-26-2019 03:52 AM - edited 06-26-2019 03:54 AM
Hi River,
you should write just the header before your loop.
No need/sense to append data to the header before the loop…
(THINK DATAFLOW!)
One more hint:
When using string constant you should make the display style indicator visible. Especially when you use \-codes in the string…
06-26-2019 04:13 AM
Hi GerdW,
It works, Thank u!
I try to follow the pdf. step by step until I found ''\n'' had been used in the code, what the result shows:
Ch101-DCV Ch102-ACV-V \n+9.90000000E+37.................. which means the end of the line function doesn't work somehow..
Also, since what you mentioned work fine so I try to add something more which is match pattern to remove comma in the result(in PNG), but it removed every results after comma
Best wishes
River
06-26-2019 04:20 AM
Hi River,
Read message #4 again…
Read the help for MatchPattern to know what to expect from it's outputs.
Read the help!
06-26-2019 05:10 AM
Hi GerdW,
I found 'search and replace string' function is useful.
Thanks for your help.
Best wishes,
River
