Modbus RTU serial communication
Greetings everyone. I am a test engineer that is having some strange issues with a test system that is utilizing a labview program written with labview 2017.
I am not the author of the software and unfortunately the software engineer is no longer here. It is utilizing modbus communications via a national instruments 485 card. Specifically an eight channel card to test 8 products at a time. We are periodically receiving timeout errors causing the test to fail. It is a pretty large program utilizing LV class architecture which I am really not that familiar with. However, after searching through the project and all of the sub VI's used within the program I finally found the VI that sets up the communication protocol.
My specific question is this: The protocol is hard coded in the program and it is different from the port settings on the computer which is running Windows 11 I believe. The program is set up to use 115,200 baud with two stop bits. The computer settings are 9,600 baud with one stop bit.
Could this cause a potential problem as far as communication timeouts or inability to periodically read registers from the processor which is an MSP 430. Does it matter that they are different or should I set the port settings on the computer to match the settings in the software?
Thank you for any guidance or information you can provide.
(1,014 Views)
Hello Dragon,
The baud rate is based on the UUT/Device you are trying to communicate.
(994 Views)
The settings are correct for the device. I just wasn't sure if the computer port settings also had to match.
(987 Views)
