Modbus RTU - CRC Calculation
I use the attached VI to calculate the CRC for the regular 16 Bit parameter value and generate the full command to be transmitted by a Modbus -RTU master.
I now have a requirement to handle 32 Bit parameter for a Bonfiglioli VFD command. The required structure is given below.
Query is whether I can use the same VI to generate the CRC and  form the required command by only modifying the 16 bit parameter value to 32 bit parameter value?
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
Message 1 of 9
(10,196 Views)
I don't see how, unless you have the password to that VI.
There should be plenty of CRC for Modbus RTU on the forum... They usually are not password protected.
Message 2 of 9
(10,166 Views)
Oh... sorry. Now its opened up !
Raghunathan
Message 3 of 9
(10,127 Views)
Accepted by topic author MogaRaghu
Hi MogaRaghu,
Your VI currently already calculates the CRC for a 32bit input: the input is just splitted into 2 16bit controls…
See this:
It's the correct result according to your example image!
Right now the problem is to calculate the correct CRC for 16bit input data.
Other problems are all those Rube-Goldbergs in the block diagram…
Message 4 of 9
(10,121 Views)
So bad ?!  Well the logic for the CRC calculation was helped by someone here in the forum and I have been using it for long.  Never pondered to study / simply it.
Why fix something that is not broke 😄
Raghunathan
Message 5 of 9
(10,070 Views)
To improve it.
Message 6 of 9
(10,064 Views)
I also wander about this.
It's messy (bended wires) but there isn't that much code, and I don't see much that can be done more easily.
Message 7 of 9
(10,063 Views)
RubeGoldberg:
  • determine last iteration by comparing the loop iterator for "==" when you could check for "<>"
  • negating the result of that check using a NOT when you can switch the conditional terminal
  • using a while loop when you should use a FOR loop!
Message 8 of 9
(10,061 Views)
@GerdW wrote:
RubeGoldberg:
That's really one point... If you change the last one, the others simply go away.
Sure some room for improvement.
Let's define Rube Goldberg Code as "exceedingly complex LabVIEW code that perform simple tasks in very indirect and convoluted ways"
It's not that bad.
Message 9 of 9
(10,055 Views)
