ModBus IO server build problem...
Greetings,
My application calls for a target computer to function as a modbus master, thus I've created a modbus IO server.  Everything works well, the problem is when I try and build an executable that deploys both the IO server and the shared variables in the project library.  I've tried various options and Ive gone through all the documentation I could find, but still the problem persists.  So my question is what are the relevant steps that are needed to successfully build an installer / exe to get all the necessary files across to the target computer so that all the variables and the IO server successfully deploys the shared variable engine.....
been hiting my head against the wallSmiley Wink
(2,946 Views)
Hi ANT0074,
Although there is some good detail in your post you didn't explicitly state your problem.  Are the variables and I/O server not being saved in the executable or are they just not deploying on the target machine when you run the executable? Can you give a little more detail on the exact problem?  Thanks.
Stephen S.
1 Test is worth 1000 expert opinions
(2,923 Views)
