How can I establish an enum typedef for use with state machines and action engines?
Hey all--
I have an action engine with several instances.  Any time that I add a method to the engine, I have to modify all of the calling code to update the constant that determines the method being called.  There must be a smarter way to address this problem but my LV experience is insufficient to identify it.  Can any of you wiz-bangs tell me if it is possible to make a type def (I can do this) and use it with each instance of the action engine call so that changing any instance also updates the typedef?
Thanks.
(3,880 Views)
I am not positive that I know what you are asking, but I will take a stab.  If you are referring to the enum ctrl, and want to be able to add states to it and have the additions automatically propagate through the VI, you can use a strict type def.  If you then turn the control into a constant 9after saving), you can copy the constant for each state case.  If you need to add a case, open the strict type deffed ctrl, change and save.  All of your constants will update to the new ctrl values.
Jim
LV 2020
(3,876 Views)
Take your enumerator.  If it is not a control (ie constant), change it to a control.
Under File Menu, select New > Custom Control.
Move (or copy) your Enum Control to the Custom Control.  Change the Control to Strict Type Def (the selection to the right of the wrench).  Save it.
(EDIT: ** OOps, the picture shows the wrong one.. sorry**)
Copy that new Strict Type Def control to your code.
See images below.
OR.. If you're using LV8.x, and using a project, I would recomment that you do it from within your project explorer.  Simply insert a new "Control".  The rest of the steps are similar, except that you can insert it from your project.
R
Message Edited by JoeLabView on 07-08-2008 06:47 PM
(3,871 Views)
Jim--
Thank you!  That is exactly what I needed.
kc64
(3,870 Views)
