Mixed signal graph- Digital Data not able to See on graph
I am trying to plot digital and analog data on Mixed signal graph. I am not able to observe digital data on graph but when I export that data to excel it shows all the digital plots also. I think I am missing some setting.
Please check attached VI for reference and let me knew if anyone know the solution
Jaysha
(4,408 Views)
Can you please post the VI in 2011 version.
(4,405 Views)
Check Vi in 2011.
(4,398 Views)
Hi Jaysha,
Data is displaying on Graph. Change X-scale value.
Check your x-scale of Digital & Cluster waveform. Both scales have different values.
Edit: Make it Sample rate 1
Munna
(4,395 Views)
Thank you Munna.
But I am plotting same sample foe digital data and analog data. I also need to display them on same graph. What I can do so that X scale will be same for both AI and DI data. I think Digital Data is in compressed format  which will not be synchronised with Analog data.
JaySha
(4,382 Views)
Accepted by Jaysha_18
I changed Sample Rate to  "1".
Munna
(4,376 Views)
This will solve my problem I think.
Just one more question. Is this sampling rate of 1 second refer to appending 1 sample whenever we call spreadsheet string to Digital.vi function?
Thank you one again Munna 🙂
(4,368 Views)
