Mixed function generators to mixed signal waveform graph
Hello, here is this vi which I do not understand how to align together. I tried and tried but I don't get it.
Can someone help me? I am trying to have the two clusters created and then merge them into a single mixed waveform graph. How would you do that?
Message 1 of 10
(4,480 Views)
You need a subVI to actually generate the functions.
I would recommend you learn more about LabVIEW from here. How to Learn LV
Message 2 of 10
(4,467 Views)
This is hard. I don't know how to create a function generator to mix two signals. Can you help?
Message 3 of 10
(4,410 Views)
Look in the Express palette to find some Express VI's to get a quick start.
Once you're ready, you can move onto the real VI's that are in the Signal Processing palette.
Message 4 of 10
(4,407 Views)
I tried many things but I can't. I can't even get signal from the first cluster.
Message 5 of 10
(4,400 Views)
Attach your latest VI.
Message 6 of 10
(4,396 Views)
Here is my last VI.
Message 7 of 10
(4,388 Views)
Why are you taking your signal you generating, then doing tone measurements built into a cluster then adding the to display on a graph?  You don't have any signal going into tone measurments,  and if you did, it doesn't make sense to build them into a random cluster that you then add together.
I thought you wanted to:
1.  Generate a signal.
2.  Generate another signal.
3.  Merge them.
4.  Display on the graph.
Message 8 of 10
(4,384 Views)
That's what I am trying to do. I just can't.
Message 9 of 10
(4,379 Views)
You really need to take some tutorials then.  Throwing together some Express VI's tends to be lesson 1 of any tutorial.
Let me show you the functions and express VI's you need.  See if you can figure out how to wire them up.
Test-1_BD
Message 10 of 10
(4,371 Views)
