Showing results forĀ
Search instead forĀ
Did you mean:Ā
Mixed data multiple devices
Hi everyone, I am trying to get data from two cameras, the output of these cameras is an array. The cameras needs a POE to work, I connect the POE to my computer and I read the data from the cameras. My problem is, the data I get is mixed, I mean, the array from camara1 is mixed with data from camera2, The cameras take the photo at the same time, they have a external trigger. How could I solve this problem?. Should I change the IP of the cameras?.
(3,116 Views)
Hi lamarck,
What is a "POE"? Are you talking about PoE = "Power over Ethernet"?
What is the current IP setting of those cameras?
You really need to provide more information before we can help you…
(3,112 Views)
Yes, I meant PoE = Power of ethernet. I checked the cameras“ IP in NI MAX and that is what I get
(3,047 Views)
Hi lamarck,
they are on different sub-nets - which is "not good" in my experience…
Usually the should be in the same subnet as your computer, so have all devices in 169.254.192.* or 169.254.103.*
(Edit: IP addresses corrected.)
(3,040 Views)
Actually, they are both Link Local addresses which means they aren't getting an IP assigned to them by the DHCP server.
(3,037 Views)
How can I change the IP of the cameras?
(3,018 Views)
Hi lamarck,
It should be explained in the manual of those cameras…
(3,008 Views)
