Mixed Signal Graph multiple plot area splitter behavior
On a Mixed Signal Graph with two plot areas, dragging the splitter that is located between the two plot areas changes the absolute height of the top plot area while keeping the height of the bottom plot area constant.   So if the splitter is dragged down to increase the top plot area height, the bottom plot area scrolls down off the graph and a vertical scrollbar appears.  I wish to keep the total sum height of all the plots constant and instead have the relative ratio of the two plot area change when the splitter is dragged, i.e. the scrollbar would not appear and the bottom of the lower plot area would remain fixed at the bottom of the graph.  Can this be accomplished and if so in a general way for more than two plot areas ?
(3,187 Views)
Hi Steve,
Normally, you can set the height and width of a graph with property nodes. Unfortunately, with the Mixed Signal Graph, those property nodes only pertain to the top graph. There is no way to set the area bounds for the other stacked graphs. This would an excellent product suggestion for our R&D department and I encourage you to submit the suggestion to them. For every new release, our team looks at these suggestions to see what new features to add.
(3,171 Views)
