How do I send a Switch Scan Complete Trigger and start a Switch Scan on a Trigger?
I have a PXI crate with a DMM and MUX. Following the examples in Labview I see how a trigger is sent to advance the switching after a DMM measurement what I would like to do is go one step forward and have the scan itself be started by a trigger (different then the scan advance trigger) and a trigger to be sent once it is done. I am using an FPGA chip to control the timing and want things to be as fast as possible.
Thanks!
Michael
(2,764 Views)
Michael,
If you are looking at example Switch Scanning with DMM - Handshaking.vi you can see that the Switch portion of the code is just DAQmx VI's, this seems to indicate to me that you could set up a regular start trigger to start the switch scanning with a DAQmx Trigger VI (to see how to use this check out any analog input trigger example).
As for exporting a trigger when the scan is complete, that is a bit more tricky, as there is no built in functionality for this.  Your best bet I believe would be to set a PFI line to 1 right after the DMM reading loop, creating an artificial trigger signal.
Doug
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
(2,741 Views)
