Mixed Graph - Problem in Zoom
I have a problem while zooming in mixed graph.
Consider the mixed graph contains two groups --> Group 0 and Group 1.
Group 0 contains Analog plots and Group 1 contains Digital plots.
If Group 0 contains two Y-scale and choose X-scale zoom in Graph Palette and while zooming in Group 1 region, the plots in Group 1 disappears.
But if I zoom in Group 0 region, there is no problem.
I have attached a Vi, that contains two mixed graph. There is a problem in second mixed graph while zooming as mentioned above.
Currently I am using LabVIEW 8.2.1
Raja
Project Engineer
Soliton Technologies
(3,587 Views)
Hi Raja,
This was reported to R&D (# 57814) for further investigation. The issue also exists in LabVIEW 8.5.1 and 8.6.  At this time, there is no workaround, though you can use two separate graphs to display the data.  Thank you for the feedback, and thank you very much for the example VI that demonstrates the behavior you described.
(3,569 Views)
Hi Steve,
Thank you for your reply. I could use two seperate graphs but i need to make lot of changes in my developed module. I am looking for some other way to tackle that problem. If at all i couldn't find a solution, then at last I am going to use seperate graphs.
Raja
(3,546 Views)
