Missing SubVI for the LabVIEW
I have this files not available to me for the IV_2015 software made by
Michael D. Kelzenberg
If anyone have an idea for the installation of the software and all the external libraries please let me know
Thank you
Message 1 of 12
(1,681 Views)
I am using IV_2015 software to test solar cells and I am getting this errors when starting the software.
It claims that the errors are due to the NI files and I am not sure.
if someone is aware of this IV software and knows how to resolve or download this files please let me know.
Thank you in advance.
Message 2 of 12
(1,550 Views)
I misread the post.
Bill
CLD
(Mid-Level minion.)
Message 3 of 12
(1,675 Views)
would be great if you can post the project or vi/ screen shot in the block diagram.
Could you able to find the subvi
-sometime you have to relink the subvi.
-or it could be in the different path, close the project and open then select correct path.
Message 4 of 12
(1,671 Views)
Hi HARSH,
Why don't you ask Michael D. Kelzenberg about his software?
Do you have those functions:
available in your LabVIEW installation?
Message 5 of 12
(1,656 Views)
Developer has closed all the contacts and software site. Also no I don't have thos functions in my library.
Although I need this files the software seems to work fine.
Message 6 of 12
(1,540 Views)
The file doesn't exist in the device or in any locations not even in temporary filles.
The file path is correct as the software demands them to be there when installing it. That means the file doesn't exist from where I took the setup file. Also it is not a file available online making it more complicated as the developer has shut down the sites and mail address.
Message 7 of 12
(1,537 Views)
Hi Harsh,
That's the problem: you miss functions in your LabVIEW installation.
You need to correct your installation!
Message 8 of 12
(1,523 Views)
@GerdW wrote:
Hi Harsh,
Are those missing VIs really the default LabVIEW VIs? I doubt it.
According to the screenshot "Initialize Keyboard.vi", "keyboardAcquire.vi" and "closeKeyboard.vi" are missing.
The default VIs in LabVIEW are "Initialize Keyboard.vi", "Acquire Input Data.vi" and "Close Input Device.vi", at least in my LV 2022 and I can't check in older versions.
To OP, I think you have to try to replace the missing VIs with the default Input Device Control VIs shown by GerdW.
Message 9 of 12
(1,518 Views)
Accepted by HARSH252525
Hi Uli,
The Acquire** and Close** functions in the palette are only place holders. They adapt according to the used Initialize** instance… (Had to check this, too.)
Message 10 of 12
(1,514 Views)
