Mismatch array elements
I'm comparing the two input arrays, I'm in need to determine the mismatch elements between two arrays.
I've attached the image for the reference.
(4,507 Views)
Hi Padmanaban,
some pseudocode:
a[] := AppendArrays( input1, input2)
FOREACH element in a[]
  bool1 := element found in input1?
  bool2 := element found in input2?
  IF bool1 NAND bool2 THEN
    append element to output[]
  ENDIF
NEXT
What have you tried so far?
Where are you stuck?
You know we will not do your homework!?
(4,500 Views)
I got struck at Array indexing while using with nested for loop.
If 1st input array index was enabled in outer loop, then I can find only the missing element from 1st array and Vice versa.
So I've to find missing elements from both input array inputs.
(4,489 Views)
Hi Padmanaban,
did you understand my pseudocode?
Your VI uses a different approach than my suggestion - maybe that's the problem? 😄
Attaching just images of code doesn't help a lot. We cannot debug/test your image with LabVIEW.
Please attach your VI!
(4,462 Views)
I've attached the snippet.
Can I do this both mismatch elements functionality within single nested forloop?
(4,458 Views)
Accepted by PadmanabanJ
Hi Padmananbad,
sure you can do it with just one loop!
As I described by the pseudocode above:
(4,450 Views)
