Mimo simulation in Control Design & simulation toolbox
I am running is simulation with MIMO system represented as state space in control design and simulation toolkit. I see that I am not able to give vector with 2 inputs to the MIMO model. By default state space is represented by a SISO model. Can anybody guide how can one give two inputs to the state space model and run it as a MIMO system.
Thanks and best regards,
Amit Kalyani
(3,744 Views)
Hi Amit,
Please upload your code.
It is impossible for us to tell why you cant give two inputs without looking at the code.
Thanks.
Ujjval
(3,717 Views)
You should be able to double click on the State-Space VI which will bring up State-Space Configuration Dialog Window. You will be able to use the drop down Polymorphic instance to selec a MIMO system. Or another way of doing this is to change the parameter source to Terminal, then wire in your MIMO model directly.
Andy Chang
(3,538 Views)
