02-25-2010 07:55 AM
02-26-2010 01:37 PM
sbenamou,
When you build your application the Application Properties Dialog Box opens up in here there is the Icon Page where you can choose different resolution Icons. Does this changing this help any?
02-26-2010 02:46 PM
Ben S wrote:sbenamou,
No, this doesn't matter. I think this option is just for viewing your configured icons and doesn't affect which one it actually uses. If you change the setting and close the application properties, this value is not saved. I also tried building with the 256x256 selected at the time and it still used the low res icon when the vi was minimazable.
03-01-2010 04:49 PM
SteffanB,
Gotcha, I'll have to test this on a Windows 7 machine to confirm the behavior.
03-09-2010 03:40 PM
Hi SteffanB,
This was reported to R&D (# 186575) for further investigation. You can try having your VI be not minimizable for now, if that's an option. I'm sorry for the inconvenience.
