Micrologix 1400 - MODBUS
I'm currently developing a project that uses the following hardware/software:
  • PC;
  • LV16;
  • DSC Module;
  • Micrologix 1400 PLC.
My goal is to read only two addresses in the Micrologix 1400: N10:5 and N10:8. As far as I have searched, there are 3 ways to develop the communication:
  • OPC Server;
  • MODBUS;
  • TCP/IP.
The first option, OPC Server, is out of question, because of limited budget. However, everytime I search for a guide, I end up in a solution that uses OPC Server. The only solutions that do not use OPC Server are not well explained.
So, my questions are the following:
  • Can I use MODBUS to communicate my PC with my PLC?
  • If yes, how do I map the tags and the addresses, i.e, in this example, NI explains how to set up a communication. However, it does not specify how I can map the address with the register. Like, I want to read the N10:5 value, how do I set up this configuration?
  • Can I use TCP/IP?
  • If yes, how do I map the tags and the addresses?
It is important for me to only use the softwares/hardwares I described above, any other purchases are out of question.
Kind regards,
André Kruger
(7,524 Views)
You can use the MODBUS capabilities of the Micrologix 1400. You will have to configure MODBUS TCP in RSlogix and use a couple of rungs of ladder logic to map your N registers to the MODBUS registers. I'm not at a computer with RSLogix but I think the MODBUS configuration is under controller properties or communication properties.
(7,461 Views)
Hello andkrugeralves,
Did you try something similar these links below?
Modbus configuration example for an Allen Bradley Micrologix 1400
http://www.mesta-automation.com/modbus-configuration-example-for-an-allen-bradley-micrologix-1400/#p...
Setting up the Allen Bradley Micrologix 1100 & 1400 for Communications via Modbus RTU Slave
http://www.plcengineers.com/micrologix_modbus_rtu.html
I don't know if I am correct, but I understood that you have first to configure the adresses inside RSlogix, as jbesselm said, and as showed on links above.
(7,449 Views)
