Metrohm Dosimat 665 driver for Labview
Is there anyone who has or who knows where i could get drivers for a
Metrohm Dosimat 665 (Serial Device) with/for LabView ?
(4,425 Views)
You can download it from the following address. As far as I know, this driver is supplied with LabVIEW 6.1 (On the drivers CD).
http://zone.ni.com/idnet97.nsf/9b2b33e1993d877786256436006ec498/8ef357fbe53e4599862568ab005fbd47?OpenDocument
Most Metrohm Instruments are easily controlled by RS-232 (See the user manual for the Instrument).
The Programming is actually so easy, that drivers are really unneccessary.
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(4,425 Views)
I'm having trouble using this driver. I'm using the 8 pin (Dosimat end-round) cable to 25 pin (PC end) and the converting the 25 to 9 pin so I can use it with my PC. I'm able to communicate with the Dosimat using an old QB routine which makes this all the more frustrating. ... any thoughts?
(4,425 Views)
> .. any thoughts?
QB has the habit of automatically adding a carriage return or line feed
to every sent string. Does your LabVIEW driver add a \r or \n (enable \
codes in the pop up menu) at the end?
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(4,425 Views)
