Methods for communication with OPC Server
There are many ways to communication with OPC server. Which method is suitable when there are approx 400-700 tags and there are possibility that same tag require to run in different vi's parallel ?
1. Shared variable node and front panel bounding  ?
2. Shared variable block diagram (Read variable.vi and write variable.vi) ?
3. DataSocket ?
4. OPC UA Toolkit
(2,426 Views)
Not sure what that means. I don't think that should make a difference.
AFAIK, OPC is slow, no matter what you use. The number of tags would not be a concern, at least not if there's no time restrains.
(2,392 Views)
