Memory usage of big Array in sub-VI (was: Allow the creation of "Inplace"-VIs of Idea Exchange)
this thread is based on my post in the LabVIEW idea exchange.
I put my VIs in the attached .rar file.
Regards
Marc
CLD
Message 1 of 8
(4,359 Views)
I still don't see your problems with the code.
Here's the output of MY running of the code.
Shane
PS Make sure the sub-vi is not open (even if the FP is not shown) when running the program
Message Edited by Intaris on 08-19-2009 11:11 AM
Message 2 of 8
(4,356 Views)
A VI CAN re-use the buffer of teh calling Vi under the proper conditions. See teh "Clear as Mud" thread where Greg McKaskle lifts the hood and tells us what we are looking at.
Ben
Message 3 of 8
(4,347 Views)
Hmm, I get without opened Sub-VI "delta t 1: Step into Sub-VI=60ms" (I still cannot upload images, therefore see attachment).
I will check the thread Ben mentioned and see, if I missed some optimization.
Marc
CLD
Message 4 of 8
(4,317 Views)
Wierd.
I'm using your VIs, unchanged except for an obligatory re-compile in LV 2009.
What version LV are you using?
Do you have any tools which monitor VIs which are loaded which may be responsible for loading the FP into memory even though it's not visible?
Shane.
Message 5 of 8
(4,309 Views)
Accepted by topic author Marc Blumentritt
I just tried in LV 8.5.1. I see a delay like Marc. I think the problem has to do with constant folding. When I change the constant in "initialize array" to a control it can't fold it, and then "delta t 1" becomes 0. This is usually closer to reality anyway.
It looks like LV has to copy the constant folded array (in LV 8.5) when it is passed to a SubVI.
Daniel
Message 6 of 8
(4,296 Views)
That would be a good explanation.  There was a thread on something very similar to this recently.  Can't remember exactly the topic but Daniel's answer certainly triggered some memories of a very similar discussion taking place.
I think it had to do with LV assigning a Array created as a constant as Read-only so in order to make changes to it it needs to be copied to a new memory location, thus leaving the constant unchanged.
I wonder how it performs in other LV versions.
Shane.
PS: Found the thread.  HERE.
Message Edited by Intaris on 08-20-2009 03:23 AM
Message 7 of 8
(4,292 Views)
Daniel
You got it, Daniel! I have the same results.
And if you want to remove the extra and unnecessary control, you can use "random number" instead, since it cannot be "constant folded".
Big thanks for solving this mystery.
Marc
CLD
Message 8 of 8
(4,272 Views)
