Memory allocation problem with CWGraph3D
I need to refresh CWGraph3D continuously with about 10000 points. For some reason the graph allocates memory all the time and in the long run (after 24 hours) CPU's memory will become full and the application will be slow down.
I have tried to clear the graph with ClearData -function with no success. ClearData seems to clear just the graph, not the memory.
I also tried to use Request Deallocation -function, but it didn't help either.
The memory won't be relased until LabView is closed.
(2,938 Views)
"The memory won't be relased until LabView is closed."
This sounds a reference is being repeatedly opened.
Post an example, we may be able to help.
Ben
Ben Rayner
Certified LabVIEW Developer
www.DSAutomation.com
(2,938 Views)
