Measuring current and Voltage using tektronix TBS2104 on labview
I'm trying to measure high voltage and low current using TBS2104 and I want to interface it with LabView. Using plug and play, I installed the Oscilloscope drivers, but when I  ran an example on continuous acquisition of waveform, then I got an error. I have attached both error and the code here. Could you hep me?
(1,418 Views)
Hi Corks, it's best to attach the .vi file here. I'd guess the error is happening at "initialize" and you just don't have any communication with the instrument. Does it show up in "VISA resource name" and did you select it? Have you tested communication with another program, like a GUI from Tektronix?
(1,405 Views)
