Error when accessing .NET Active X control
I am using LabVIEW 2020 currently that is compatible with Kinesis Thor labs software and in order to use the software with LabView, it needs to have a NET framework of 4.5.
Which LabView version has this type of framework?
Also when trying to insert a .NET container in LabView, I am getting a specific error.
I right click on .NET container in front panel and then insert .NET control.  Once that is complete I browse and find the certain dll file from the Kinesis software  which can be seen in Snip_2.Jpg and when I click ok it gives me the error attached in Error_Labview.Jpg.
What are the next steps that I should take to resolve these issues, thank you!
Message 1 of 1
(1,071 Views)
