Measurement of PV charachteristics of Solar Panel
Hallo Guys
This is how the connections are made.
Message 11 of 13
(411 Views)
You still haven't shown your entire system wiring.
Fact is this is not a LabVIEW issue.
You have a problem with your test setup and it is impossible to troubleshoot or even guess without a proper schematic diagram.
Find someone locally with an electrical engineering background that can help you troubleshoot your test setup "on site".
I am done here.
=== Engineer Ambiguously ===
Message 12 of 13
(407 Views)
Hi RTSLVU
Thank you for your support. This is the entire setup it is just repeated for the other panels and the panels are connected as per the other two diagrams. I will post the solution when I find it.
Message 13 of 13
(403 Views)
