04-26-2014 05:00 PM
Hello guys, i have a wii balance board and i connected the board to pc with bluesoiel, but i can't get a good VI for LAbview 2013 to take the data from board. I search all on the internet and i don't have succes(i hope i wrong on this). Please can somebody help whit my problem? Thanks
04-26-2014 05:13 PM
Have you read through this thread?
Please be as specific as possible about what does not work. What have you tried? What results do you get? What errors do you get?
Lynn
04-27-2014 03:38 AM
Hello, yes a pass out on the all thread's, but i can\t find a good vi for labview 2013 to test the board. I will search again . Thanks you.
04-27-2014 12:52 PM
04-27-2014 02:37 PM
Thnaks but the link don't work.
04-27-2014 02:54 PM
I have tested a vi from the top link of topic but I get this error. What I am doing wrong? I want to get data from balance board.
04-27-2014 04:14 PM
That error you get indicates that you don't have the wiimote .net library installed. Follow the directions in the text box on the front panel of that vi you showed. You need to establish comms with the wiimote via bluetooth before the VIs can be used. You can search the NI forums for the article by Sam Shearman:
The whole set up procedure is there.
JohnCS
