Measure weight with Wii balance board and LAbview
Hello guys, i have   a  wii balance  board and  i connected the board   to pc with bluesoiel, but i can't  get a   good VI for LAbview 2013 to take the data  from board. I search all on the internet and i don't   have succes(i hope i wrong on this). Please  can somebody help whit my problem? Thanks
(4,056 Views)
Have you read through this thread?
Please be as specific as possible about what does not work. What have you tried? What results do you get? What errors do you get?
Lynn
(4,051 Views)
Hello, yes   a pass out on the all thread's, but i can\t find a   good vi for labview 2013 to test    the board. I will search again . Thanks you.
(4,009 Views)
Check out the LabVIEW Wiimote Interface Project at LabVIEW Hacker.
JohnCS
(3,992 Views)
Thnaks  but  the  link don't work.
(3,986 Views)
I have tested a  vi from  the top link of topic but I get this   error. What I am doing  wrong? I want  to get data   from  balance board.
(3,980 Views)
That error you get indicates that you don't have the wiimote .net library installed.  Follow the directions in the text box on the front panel of that vi you showed. You need to establish comms with the wiimote via bluetooth before the VIs can be used.  You can search the NI forums for the article by Sam Shearman:
                 LabVIEW interface to a Wii Remote
The whole set up procedure is there.
JohnCS
(3,965 Views)
