Measure Time?
Very close to what i wanted
i will play with it more
Message 21 of 28
(1,029 Views)
What could be the way to find the time duration when Red plot is greater than white plot?
Should store the values in the same table.
Message 22 of 28
(1,029 Views)
Here is what I did. I hope this helps
Tim
GHSP
Message 23 of 28
(1,019 Views)
I actually have the Time for W above R and the Time for R above W.
But, i need to know how to show and store both of them in the same table.
What you have here is just time for W above R.
You can use another comparison logic for R above W. I just need to know how to store the time for both in the same table,
Message 24 of 28
(1,015 Views)
This should work
Tim
GHSP
Message 25 of 28
(1,012 Views)
Tim
I am just trying to figure out how you exactly did that?
This is correct,
But i just figured out that when Red is greater than White, it does not time in real time (ms). I just calculated with my watch, for 8000ms it would give me 37000ms .
Where as when White is greater than Red it would time correctly.
Is that since you are not using the comparison function for Red>White
Message 26 of 28
(1,009 Views)
I did find one error so I fixed that. Then I added a mechanisim to time each control for seconds on and five seconds off to see if it was calculating properly. Let me know if you find anything else.
Tim
GHSP
Message 27 of 28
(1,005 Views)
Tim
i was wondering if you could help me out with the program.
it is a bit related to what we have discussed before
I have explained it in the following link
http://forums.ni.com/t5/LabVIEW/InRangeCompareFunction/m-p/1577320
Message 28 of 28
(984 Views)
