Maximize Window Programattically
  I'm trying to make a VI that the user has no way of moving the window.  I figured that I may be able to do that by somehow forcing the VI window to be maximized when run.  Does anyone have any ideas how to do this in Labview 6.1 or another idea as to how to force the front panel window to be fixed?  Any suggestions would be appreciated.
PP
Windows XP, LV6.1
(3,917 Views)
If you right click on the icon on the VI's front panel you can access the vi's properties. Under Window size you can select size front panel to full screen, and under the Window apperance/customize you can check boxes that prevent the user from closing, etc. I'm not sure exactly how they are described in 6.1, I think that it changed from 6.x to 7.x
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,900 Views)
Hi PP
under vi properties : customize window appearance -  you can  disable the users option to resize window
 under vi properties:  under window size - you can allow  vi FP to cover whole of  screen
Hope that helps
xseadog
(3,897 Views)
You can set the window size prior to running by right clicking on the icon (front panel) and going into VI Properties->Window Appearance->Customize, and from there you can make it a certian size, and so that it can't be resized, etc.
Also, you can do this sort of thing in your program by creating a reference to the vi itself, and wiring that to a property node, and you can change all sorts of things in there too.  This way however, requires that the vi be loaded into memory first.
Edit:  Guess I got beat to the chase!  If only I could type a little faster...
Message Edited by Novatron on 08-11-2005 09:45 AM
(3,893 Views)
HI xseadog and PM,
  I've checked both of your solutions and unfortunately, some things have apparently changed from 6 to 7.  The only option on window size is "Size the Front Panel to the Width and Height of Entire Screen".  Sounds good, no?  But alas, the window is truly not maximized, only as big as the screen, which means the user can still move it.  Any other ideas?
PP
(3,890 Views)
Uncheck all the "allow"s on the right side and the window title on the left side. This should prevent the user from touching the windows.
You can also control the window size programmatically by creating a property node, changing it to the VI class (right click>>inside VI server) and selecting Front Panel Window>>Size to Screen or Window Bounds.
Edit: I was refering to the Window Appearance screen Novatron was talking about.
Message Edited by tst on 08-11-2005 04:57 PM
___________________
Try to take over the world!
(3,882 Views)
Thanks tst,
  I think I must have been having a duh moment.  Works like I want it to now by removing title bar.  Thanks alot,
PP
(3,878 Views)
