Max number of AVI file refs open simultaneously?
I am getting this error when I try to open a bunch of AVI files at the same time:
-1074396001 There are too many AVI sessions open. You must close a session before you can open another one.
I can't find a reference to this limitation anywhere in the Vision literature.  Can someone explain this limitation?
And also explain why it exists?  To me, it sounds like a poorly implemented feature.  I have never seen this behaviour using any other types of files.  IMHO, this should only be limited by the amount of memory.
I have a very powerful PC, and I want to cache these file references as I open them.  Yes, of course, I know there are workarounds.   But first:  what is the exact limitation here?
http://www.medicollector.com
(4,463 Views)
Well, we've got an application with 24 cameras monitoring 24 experiment stations, capturing "events" (5-10 second epochs surrounding a digital event), writing the data as AVI files.  Because of the asynchronous nature of the independent events, I don't know how many AVI files are simultaneously open, but I don't recall a "Too many AVI sessions" error.  I'll have to ask my colleague who's actually collecting the videos ...
(4,452 Views)
Hi josborne,
I'm currently working on digging in to this, but while I dig, I was curious how many AVI references you were opening?
(4,438 Views)
Hi joshborne,
After some testing, we have determined that the maximum number of open references that you can have is 31.  I was able to open up 31 references simultaneously without error, but as soon as I try opening up a 32nd reference, I receive the same -1074396001 error.  As I believe you already know, the workaround is to maintain less than 32 references open by closing the references in a timely manner.  If you close an AVI reference before you create a new one, then there should not be an issue.
Hope this helps,
(4,431 Views)
