04-26-2006 12:38 PM
04-27-2006 05:56 PM
04-28-2006 07:56 AM
05-01-2006
04:01 PM
- last edited on
07-22-2026
04:15 PM
by
Content Cleaner
Hi DaqProblem,
You are using the correct command to open the Matlab GUI (as discussed in KB 3Q56TJL2) although the interface is limited. The Matlab script node simply calls the Matlab Script Server and is limited by the functionality this exposes. There are also possible problems because you have multiple versions of Matlab installed. Check out KB 2A6E3SDM for more information on this. Uninstalling the version of Matlab you are not using might help.
I hope this helps!
Megan B.
04:27 AM
- last edited on
07-22-2026
04:16 PM
by
Content Cleaner
Hi
Try using run command instead, like
run('yourmfile') %the name of the m-file without .m. Remember to use ' '
or take at look at my post here
Hope it works
Simon
11-15-2007 04:27 AM
Hi
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=284468#M284468
Hope it works
Simon
11-15-2007 04:27 AM - edited 11-15-2007 04:29 AM
11-15-2007 04:27 AM
Hi
Hope it works
Simon
11-15-2007 04:29 AM
08-28-2011 09:43 PM
The right way to call a GUI in command line is GUIname(), before which you must ensure current path is correct so that matlab can find the mfile of GUI
