Showing results forĀ
Search instead forĀ
Did you mean:Ā
Mathscipt node issue
I did. They submitted to R&D and closed the case.
Message 11 of 15
(2,094 Views)
OK, there must be a CAR# in their system to track the bug. I guess you never got the number...
Message 12 of 15
(2,084 Views)
OK, I wrote a pure g replacement and it seems more robust.
Here is some simple code to calculate N and D for any input X such that N/D ~= X. See if this works for you.
(I also included a little tester to measure performance and failure count. Note that this is just a draft. Once polished up, I will probably post it in a dedicated place elsewhere. For typical tolerances of 1e-6, the computation takes about 500ns).
Message 13 of 15
(2,052 Views)
CAR 702329
Message 14 of 15
(2,024 Views)
Thanks, it's matched matlab in all the cases I tested.
Message 15 of 15
(2,005 Views)
