Match Pattern regular expression SELECT
@GerdW wrote:
Hi Fredo,
@Fredo123Danzel wrote:
I would like to select:  Re= 45763.
What makes you think you need a RegEx here?
In case of "invalid" values after the keywords you still can use InRangeAndCoerce to check the parsed data…
It would seem important to wire a U16 constant to the default value inputs here, because that's probably the datatype we need later.
  • If the number in the string is >65535, you'll get it coerced to 65535 (no error!)
  • If the number is negative, it will be coerced to zero (no error!)
  • if the string is not a number, you'll get an error or the error out.
Message 11 of 12
(629 Views)
@Yamaeda wrote:
Ah, so this was a typical case of OP posting "how" they want to solve something instead of "what" they want to achieve. I assumed it was some RegExp drill ...
The ol' XY problem 🙂
Message 12 of 12
(597 Views)
