Match Pattern regular expression SELECT
Has anyone ever used the regular expression for a number between 0 and 65535 (FFFF), please?
6553[0-5]|655[0-2][0-9]|65[0-4][0-9]{2}|6[0-4][0-9]{3}|[1-5][0-9]{4}|[0-9]{1,4}
I WOULD LIKE TO SELECT A NUMBER FROM THIS RANGE BUT THE MATCH PATTERN DOESN'T RECOGNIZE IT
Message 1 of 12
(3,318 Views)
^(65535|[1-9]?[0-9]{1,4}|[1-5][0-9]{4}|6[0-4][0-9]{3}|65[0-4][0-9]{2}|655[0-2][0-9]|6553[0-5])$
Match pattern uses a simplified function, use Match Regular expression.
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 12
(3,306 Views)
Try this:
\b(?:[0-9]|[1-9][0-9]{1,3}|[1-5][0-9]{4}|6[0-4][0-9]{3}|65[0-4][0-9]{2}|655[0-2][0-9]|6553[0-5])\b
Tim
GHSP
Message 3 of 12
(3,304 Views)
<message deleted - doesn't work for all cases>
Message 4 of 12
(3,288 Views)
You could also do something more simple like this:
Tim
GHSP
Message 5 of 12
(3,283 Views)
So you have a decimal string and would like to see if its hex formatted numeric value is in the range 0-FFFF. Can you explain what you mean by "select from this range"? Is this "number" in a fixed string position? Is it surrounded by known delimiters?
it might be easier to do things numerically.
Message 6 of 12
(3,258 Views)
I would like to select:  Re= 45763.
This number is between 0 and 65535.
Message 7 of 12
(3,209 Views)
Accepted by topic author Fredo123Danzel
Hi Fredo,
What makes you think you need a RegEx here?
In case of "invalid" values after the keywords you still can use InRangeAndCoerce to check the parsed data…
Message 8 of 12
(3,194 Views)
He Knight OF NI,
Thank you! Your idea helped me solve my problem.
Message 9 of 12
(3,181 Views)
Ah, so this was a typical case of OP posting "how" they want to solve something instead of "what" they want to achieve. I assumed it was some RegExp drill ...
Qestit Systems
Message 10 of 12
(3,146 Views)
