Map coords to XY
Hi everyone,
In LabView 8, even 7, the Invoke Node of a graph contains the method "Map Coordinates to XY". That is, it converts a pixelwise coordinates (ex. mouse click on graph area) to a graphwise coordinates. Unfortunately, in LabView 6.1, there is no such useful method. Does someone know an alternative solution? How can I convert pixelwise coordinates to graphwise coordinates.
Thanks for your help,
Joe
Click for cursor.vi
Joe
(4,205 Views)
I wrote this response a long time ago before I realized there were invoke nodes that would do the mapping for you. I haven't looked at this in a long time, so you should definitely doublecheck my methods and/or pixel math, but the basic idea seemed to work fine. This was designed for linear axes. You'll have to do a little work to make it work for logarithmic scales. Hope this helps!
Jarrod S.
(4,190 Views)
Here's another method, similar to Jarrod's method.
Note that you have to provide the origin of the plot area.
___________________
Try to take over the world!
(4,183 Views)
Thank you all. I finally succeed with your help! Thanks again!
Joe
(4,146 Views)
