09-07-2011 12:15 PM
How do I map Allen Bradley 1400 Micrologix addresses like (N7:0, B3:0/1, etc., etc.) to NIs modbus addresses? Can the NI DSC module access the PLC for read/write operations without using the NI OPC server?
Is there any tutorial or URL which specifically addresses the above queries?
Thanks in advance.
09-07-2011 02:48 PM
If the PLC supports Modbus communication, you can do one of two things:
1. Either use the free NI Modbus Library for LabVIEW.
2. Use the LabVIEW DSC Module. Help for that is provided under here. There are a couple of links there to help you get started with Modbus using LabVIEW DSC.
09-19-2011 10:18 AM
It's easier if you are using OPC ... you can map and bridge data between the two protocols quickly through tags (addresses).
Here is what you need:
Modbus << OPC Data Manager >> Allen Bradley
Data Manager allows one-to-one, one-to-many, and many to many relationships between tags
Let me know if you have any questions.
Wassim Daoud
Senior OPC Architect
09-20-2011 12:21 AM
Thanks Wassim and Adnan. The PLC does support Modbus protocol. However, I am told that the PLC code writer should have used Modbus addresses rather than ABs standard format like N7:0, N10:1, B3:0/1 etc. Is there a way out? Sorry if I am being naive in my questions.
Thanks in advance,
Paul
