Anritsu MW9070B OTDR Serial Interface
I want to find out if there is anyone using LabVIEW for serial communication with Anritsu MW9070B OTDR. The information I need are the com port settings and sample command strings.
(3,796 Views)
Hello-
Unfortunately I was unable to find a driver for this instrument either at http://ni.com/idnet. This leaves you with one of a couple options. It may be possible to modify an existing driver to work with this instrument. Otherwise, http://www.ni.com/devzone/idnet/other.htm states a few options to obtaining a driver. Drivers are developed based on demand and popularity so the more requests, the greater the possibility that one will be developed. It would also be beneficial to notify the instrument manufacturer.
Randy Solomonson
Application Engineer
(3,796 Views)
I have found solution to the above post. The LabVIEW vi's are attached for someone that may need it. Thanks Randy for your response.
(3,796 Views)
dear frns
how can we get the software for this ODTR? i need to trace it using my PC using USB 232C. will be very happy if someone can help me by mailing to lhaten2004@yahoo.com
(3,118 Views)
