Many Sub panels to call same VI
I would like to create a test sequencer can test on multiple device in parellel.
I have just created a VI which has 2 sub panels to call the sequencer.vi, both of the sub panels able to run the test in parallel and asynchronously.
Now my problem comes, if my VI has to test on 50 device in parellel, is that expand block diagram the only way can do it?
Anyone have better idea for future easier maintainbility and sustainability?
Here I attached my VI.
Thanks.
Message 1 of 8
(4,308 Views)
Accepted by TanTan
It is possible, just create references to the subpanels, bundle them in an array and use a for loop.
Spoiler
However, you may need to have some communication mechanism between the subvi's and the sequencer as you are not sure of the state of your sub panel vi when you click Exit on the Load Sequencer for example.
Here are some examples that may give you some poiners, there are more available if you search:
http://forums.ni.com/t5/LabVIEW/Calling-a-VI-in-a-subpanel-with-parameters-inside-an-event/m-p/23233...
http://forums.ni.com/t5/LabVIEW/Dr-Damien-s-Development-Running-Top-Level-VIs-II-SubPanel-Use/m-p/99...
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 2 of 8
(4,293 Views)
Make the test-vi reentrant and place it in a loop, configured for parallellism, done. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 8
(4,271 Views)
Hi ace,
Yes the array and for loop is work! Appreciate your idea, this saves me a lot of job!
Now I am thinking how to simplify the area as shown in picture below.
If i create a string combo or numeric control in the front panel, for user to select the quantity of device to go for testing.
After the selection, lets say the quantity = 5 subpanels.
So in the block diagram, is there any way to auto create 5 reference of different subpanels, link them to 'build array function' and 'for loop'?
Or pre-create the references of subpanels for every single case of quantity selection, is the only solution?
Thanks.
Message 4 of 8
(4,221 Views)
Take a look at TestStand. It will save you a ton of money and time because it has parallelism built in. The basic parallellism features that are built in already in TestStand will take months to develop from scratch in LabVIEW. If future maintainability is important, it's worth spending just a little bit of time learning to use TestStand.
S G
Certified LabVIEW Architect, Certified TestStand Architect, Certified Professional Instructor
Message 5 of 8
(4,217 Views)
@TanTan wrote:
Hi ace,
Thanks.
You can Open reference to a file (.vi) in a loop, just add some function to generate the name of which file to open, e.g. Subpanel1.vi and so on, and it's quite simple to generate and open the references.
/Y
Qestit Systems
Message 6 of 8
(4,206 Views)
Bundle the references and then use a array subset or something similar to extract a portion of the array of subpanel references. So if you have 10 subpanels, and the user selects, 3. Derive the first 3 elements from the array and use it in the for loop as before. Hope this helps.
Message 7 of 8
(4,180 Views)
Hi ace,
Your idea works! It save me a lot of jobs again!
Thanks a lot!
Message 8 of 8
(4,157 Views)
