Manipulating waveform data type
Hi all,
I have an array of 1D waveform data coming out of DAQmx Read.vi. I want to be able to add or multiply all a specific scalar number to all of the data points in a specfic channel (element in the array). What's the easiest/most efficient way to go about doing this?
Thanks!
(3,718 Views)
Accepted by topic author RaymondLo
There is a "Waveform Scale and Offset" in the analog sub-palette of the Waveform palette.
If you want to scale each elemement in the array uniquely then put that VI is a For loop and pass the scale and offsets you need.
Ben
(3,715 Views)
Beautiful. Thanks.
(3,710 Views)
