Manipulating bytes in a byte array and displaying them as 16 bit signed int in a waveform chart
If you shift a byte by 8 places, you have nothing left. If you unflatten your two-byte string to a 16 bit integer, everything is already in place.
Message 21 of 23
(1,347 Views)
Accepted by topic author lking
Ok that sounds much better. Thanks for help.
Message 22 of 23
(1,344 Views)
Typically you would make sure that the code actually works and then mark the most helpful post as solution (not you own thank you post!)
Message 23 of 23
(1,338 Views)
