Manipulate xy-graph to re-define axis value
Hi!
 I have a program that will output to an xy-graph. I now want to change the axis so that the biggest value on my y-axis at the end of the measuremet is set as zero, and all other values changed with respect to the new zero point. I am not sure what i should do to accomplish this. I was wondering if anyone knows how this can be done. The graph is created in a sub-VI and outputed to the main VI afterwards.
Thank you!
(2,642 Views)
You can use the Array Max&Min function to find the max value and then subtract that from the array.
Message Edited by Dennis Knutson on 05-08-2007 03:01 PM
(2,637 Views)
