Managing user disappointment
SO, I did code this up and present it to some users for feedback.  The first attempt involved flashing the numeric display red/ Green.  Lynn, Thanks for not laughing too hard, one operator had a condition you are familliar with.  Worse, the users had a tendancy to ignore the display since the pot adjustment involves a magnifying lens that they need to look through focused nicely on the pot.  (Actually a very cool feature that totally helps align the captivated and spring loaded tweaker blade tip with the slot on top of the pot.)  The Hardware guys aren't completely helpless.
Round two and new operators
Not the first time I've used that method but, the users looked up and back down while adjusting the pot slowly.  Reset is still only handllable by the brute force change user instructions "You have failed ..... try to test it after it cools down"  total abort... you cannot win.
Design for Test
Design for Maintainability
Design for Manufacturability
Gosh, those DFx's are importantSmiley Frustrated
"Should be" isn't "Is" -Jay
Message 11 of 15
(1,468 Views)
If the users tend to ignore the display or it’s difficult to adjust and see the display at the same time have you considered providing them with and audio feedback of some kind.  I was thinking something like back up sensor sounds like in a car.  A sound is repeated at certain frequency and the closer an object the more frequent the sound is repeated until eventually it is played continuously.
Ding……….Ding…..Ding…Ding.Ding.Ding
Herrlin
Just trying to spread the LabVIEW love.
Message 12 of 15
(1,450 Views)
I did try that.  Nice thought.  Does not work for two reasons:
  1. Production floors are noisy enough
  2. industrial pc with speaker is at ankle level in the rack supporting the fixture - wrong place to re-direct the users attentionSmiley Wink
Message 13 of 15
(1,443 Views)
If audio is not an option, how about a visual prompt?  Is there anywhere you could mount an RGB LED in the operators field of view?
You could flash it blue during adjustment, with the flashes increasing in frequency as the setpoint was approached, turn it green at the setpoint and red if the unit overheats.
Cheers,
  MC
Message 14 of 15
(1,422 Views)
1. True, but a melodic sound is probably distinguishable.
2. Use a long speaker cord and place a speaker close to the operator and a usb-light or something. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 15 of 15
(1,356 Views)
