Making enum with string cases
I have a case structure with multiple string cases.  Would it be possible to use the info from the case structure to make an enum?  Is there a script out there that can do that?  When I am making a state machine, I like to develop my states first and my my enum later.  It is hard for me to make an enum with all the cases first. What's your preference?
Message 1 of 26
(5,312 Views)
Did you try a search?
Dr. Damien's Development - Creating an Enum from a Text Case Structure
I don't understand your statement: "It is hard for me to make an enum with all the cases first". You may not know all the states ahead of time, but I don't understand where the difficulty is. Is it because you are not making the enum a typedef? By making it a typedef you can add/remove states and make sure the case structure stays consistent.
Message 2 of 26
(5,308 Views)
Sorry, I didn't mean to use the word difficult.  I do use type-def already, but I just find it troublesome to modify the enum multiple of times.  I only want to update it one time.
Message 3 of 26
(5,304 Views)
You should know a large percentage of the cases you need in a state machine before you even start coding.  Therefore the enum should not be changing all that much.  Even so, the enum editor is not that bad.
Message 4 of 26
(5,293 Views)
That sounds like you never will modify the software. Smiley Very Happy In my experience that is just wishful thinking. As soon as the application works you or whoever is using your application will come up with new requirements to include.
Rolf Kalbermatter  My Blog
Message 5 of 26
(5,291 Views)
Now if only there was a tool that would let you define the states and the transitions and then create the code for you.  It would be so simple to add, remove and edit transitions.  Nah, that is just crazy talk....
Message 6 of 26
(5,276 Views)
Yep, complete crazy talk.
Message 7 of 26
(5,255 Views)
haha.  I meant one time during the first development.
Message 8 of 26
(5,213 Views)
At one point, there is a state editor that comes with labview?  I always thought that there is only the separate module.  It will so convenient if they bring the editer back.
Message 9 of 26
(5,215 Views)
I do not have an answer to your posted question but I have to ask out of concern.
Are you writing code before you know what the design will be?
In my minds eye writing code without a design is like starting a journey without knowing where you are going. Sure it may be a fun adventure but I would be suprised if it result in an efficent path to a solution.
Concerned,
Ben
Message 10 of 26
(5,206 Views)
