05-19-2006 07:40 AM
05-19-2006 08:05 AM
05-19-2006 08:29 AM
Maybe I'm quite an expert - don't know.
Anyway, unfortunately I can't give you any advice for books. But there already were some titles mentioned in the forums - just search.
By the way - I'd be pleased if you could spell my username correctly.
Nevertheless, it's always nice if I could help solving a problem.
05-19-2006 08:36 AM
05-19-2006 08:39 AM
05-19-2006 10:30 AM
Monk,
A side note since this was just a demo, but you're using LV6; are new; and have discovered property nodes that output refnums:
Close those refnums that have been opened implicitly by property nodes or you'll have a memory leak.
There's an good discussion on the subject here: http://www.ni.com/devzone/lvzone/dr_vi_archived4.htm
Automatic handling of refnums improved in more recent versions of LabVIEW. You don't have to worry about it if you follow becktho's advice to right-click the control(s) > create reference and build an array instead of using the Controls[] property.
... and your life may become easier if you make use of the ubiquitous Error cluster.
