Making a cursor invisible?
Does any one know how i can make my cursor turn transparent while I am running a labview program? I'm finding it rather obtrusive to have my mouse visible at all times during the program when it doesnt need to be
"There will be water if God wills it"
Message 1 of 20
(4,352 Views)
This is a good place to start:
https://decibel.ni.com/content/docs/DOC-9253
Prashanth N
Message 2 of 20
(4,327 Views)
You can also do this using User32.dll
https://decibel.ni.com/content/docs/DOC-17854
Just make sure to set the cursor back on when you are finished!
Steve
Stephen C
Message 3 of 20
(4,315 Views)
I think making the cursor transparent is a BAD idea. What happens if your program crashes? Now you can't see the cursor. If it's obtrusive, then move the cursor off to the side. You can do this programmatically if you need to.
Message 4 of 20
(4,305 Views)
Ctrl-alt-delete and cancel should return the cursor to a useable state.
Message 5 of 20
(4,294 Views)
Not only that but the mouse will probably still be functional. If you don't know where the cursor is and click then who knows what will happen.
LabVIEW 2012
Message 6 of 20
(4,284 Views)
However, when running on a touch screen its juicy ..unless the touch screen driver should crash that is.. Smiley Happy
Message 7 of 20
(4,280 Views)
Ah, but that's the fun part. Best done with an "Are you sure you want to format c:?" window up.  :rofl
Message 8 of 20
(4,266 Views)
I agree with S-mercurio.  Don't mess with the cursor.
Message 9 of 20
(4,255 Views)
Look i'm making it invisble because my boss wants it that way but moving it to the side is not an option. It's not a high maintenance program so i'll take the risk of a computer crashing but if it does i'm sure i will figure something out. Thank you for your suggstions though and Stephen that looks great thanks
Message 10 of 20
(4,245 Views)
